- Sat Jan 30, 2021 2:10 pm
#222796
Because Artemis uses RTOS, the interrupts in OneWire.cpp are not defined for the Artemis. This causes errors wherever interrupts() and noInterrupts() are declared.
I replaced noInterrupts() with detachInterrupt(...) and interrupts() with attachInterrupt(...) and it compiles but I have no idea if what I wrote is technically equivalent to what the interrupts in OneWire were doing (there is a difference between external and internal interrupts). The implementations of detachInterrupt() and AttachInterrupt() are based on the code examples in Apollo3.
I haven't tested the code with a OneWire device yet but I wanted to know if there have been any efforts to make OneWire compatible with Artemis.
The revised OneWire.cpp is attached.
