I installed 1.2.1. I got the following error when compiled the code:
Code: Select allArduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "SparkFun RedBoard Artemis ATP, 115200, SparkFun Variable Loader (Recommended)"
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'bool beginSensors()':
Sensors:87:37: error: 'UBLOX_CFG_I2COUTPROT_UBX' was not declared in this scope
gpsSensor_ublox.newCfgValset8(UBLOX_CFG_I2COUTPROT_UBX, VAL_LAYER_RAM | VAL_LAYER_BBR); // CFG-I2COUTPROT-UBX : Enable UBX output on the I2C port (in RAM and BBR)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:87:37: note: suggested alternative: 'VAL_ID_I2COUTPROT_UBX'
Sensors:88:37: error: 'UBLOX_CFG_I2COUTPROT_NMEA' was not declared in this scope
gpsSensor_ublox.addCfgValset8(UBLOX_CFG_I2COUTPROT_NMEA, 0); // CFG-I2COUTPROT-NMEA : Disable NMEA output on the I2C port
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:88:37: note: suggested alternative: 'VAL_ID_I2COUTPROT_NMEA'
Sensors:91:39: error: 'UBLOX_CFG_I2COUTPROT_RTCM3X' was not declared in this scope
gpsSensor_ublox.addCfgValset8(UBLOX_CFG_I2COUTPROT_RTCM3X, 0); // CFG-I2COUTPROT-RTCM3X : Disable RTCM3 output on the I2C port (Precision modules only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:91:39: note: suggested alternative: 'VAL_ID_I2COUTPROT_RTCM3'
Sensors:93:56: error: 'UBLOX_CFG_INFMSG_UBX_I2C' was not declared in this scope
uint8_t success = gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_INFMSG_UBX_I2C, 0, 2100); // CFG-INFMSG-UBX_I2C : Disable UBX INFo messages on the I2C port (maxWait 2100ms)
Sensors:115:43: error: 'UBLOX_CFG_USB_ENABLED' was not declared in this scope
success = gpsSensor_ublox.setVal8(UBLOX_CFG_USB_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-USB-ENABLED (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:115:43: note: suggested alternative: 'UBX_CFG_USB'
UBX_CFG_USB
Sensors:135:43: error: 'UBLOX_CFG_UART1_ENABLED' was not declared in this scope
success = gpsSensor_ublox.setVal8(UBLOX_CFG_UART1_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-UART1-ENABLED (in RAM only)
Sensors:155:43: error: 'UBLOX_CFG_UART2_ENABLED' was not declared in this scope
success = gpsSensor_ublox.setVal8(UBLOX_CFG_UART2_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-UART2-ENABLED (in RAM only)
Sensors:175:43: error: 'UBLOX_CFG_SPI_ENABLED' was not declared in this scope
success = gpsSensor_ublox.setVal8(UBLOX_CFG_SPI_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-SPI-ENABLED (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:175:43: note: suggested alternative: 'UBX_CFG_GEOFENCE'
UBX_CFG_GEOFENCE
Sensors:262:38: error: 'UBLOX_CFG_RATE_MEAS' was not declared in this scope
gpsSensor_ublox.newCfgValset16(UBLOX_CFG_RATE_MEAS, measRate, VAL_LAYER_RAM); // CFG-RATE-MEAS : Configure measurement period (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:262:38: note: suggested alternative: 'UBX_CFG_RATE'
UBX_CFG_RATE
Sensors:263:49: error: 'UBLOX_CFG_RATE_NAV' was not declared in this scope
success = gpsSensor_ublox.sendCfgValset16(UBLOX_CFG_RATE_NAV, 1, 2100); // CFG-RATE-NAV : 1 measurement per navigation solution (maxWait 2100ms)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:263:49: note: suggested alternative: 'UBX_CFG_RATE'
UBX_CFG_RATE
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'uint8_t disableMessages(uint16_t)':
Sensors:464:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C, 0, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_CLOCK_I2C (in RAM only)
Sensors:465:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C, 0); // CFG-MSGOUT-UBX_NAV_ATT_I2C
Sensors:466:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C, 0); // CFG-MSGOUT-UBX_NAV_DOP_I2C
Sensors:467:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C, 0); // CFG-MSGOUT-UBX_NAV_ODO_I2C
Sensors:468:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C, 0); // CFG-MSGOUT-UBX_NAV_POSECEF_I2C
Sensors:469:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C, 0); // CFG-MSGOUT-UBX_NAV_POSLLH_I2C
Sensors:470:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C, 0); // CFG-MSGOUT-UBX_NAV_PVT_I2C
Sensors:471:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C, 0); // CFG-MSGOUT-UBX_NAV_STATUS_I2C
Sensors:472:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C, 0); // CFG-MSGOUT-UBX_NAV_TIMEUTC_I2C
Sensors:473:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C, 0); // CFG-MSGOUT-UBX_NAV_VELECEF_I2C
Sensors:474:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C, 0); // CFG-MSGOUT-UBX_NAV_VELNED_I2C
Sensors:475:45: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C, 0); // CFG-MSGOUT-UBX_RXM_SFRBX_I2C
Sensors:476:46: error: 'UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C, 0, maxWait); // CFG-MSGOUT-UBX_TIM_TM2_I2C
Sensors:479:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C' was not declared in this scope
success2 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C, 0, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_HPPOSECEF_I2C
Sensors:480:46: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C' was not declared in this scope
success2 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C, 0, maxWait); // CFG-MSGOUT-UBX_NAV_HPPOSLLH_I2C
Sensors:482:46: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C' was not declared in this scope
uint8_t success3 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C, 0, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_NAV_RELPOSNED_I2C
Sensors:484:46: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C' was not declared in this scope
uint8_t success4 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C, 0, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_RXM_RAWX_I2C
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'uint8_t enableMessages(uint16_t)':
Sensors:510:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C, settings.sensor_uBlox.logUBXNAVCLOCK, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_CLOCK_I2C (in RAM only)
Sensors:511:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C, settings.sensor_uBlox.logUBXNAVDOP); // CFG-MSGOUT-UBX_NAV_DOP_I2C
Sensors:512:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C, settings.sensor_uBlox.logUBXNAVODO); // CFG-MSGOUT-UBX_NAV_ODO_I2C
Sensors:513:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C, settings.sensor_uBlox.logUBXNAVPOSECEF); // CFG-MSGOUT-UBX_NAV_POSECEF_I2C
Sensors:514:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C, settings.sensor_uBlox.logUBXNAVPOSLLH); // CFG-MSGOUT-UBX_NAV_POSLLH_I2C
Sensors:515:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C, settings.sensor_uBlox.logUBXNAVPVT); // CFG-MSGOUT-UBX_NAV_PVT_I2C
Sensors:516:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C, settings.sensor_uBlox.logUBXNAVSTATUS); // CFG-MSGOUT-UBX_NAV_STATUS_I2C
Sensors:517:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C, settings.sensor_uBlox.logUBXNAVTIMEUTC); // CFG-MSGOUT-UBX_NAV_TIMEUTC_I2C
Sensors:518:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C, settings.sensor_uBlox.logUBXNAVVELECEF); // CFG-MSGOUT-UBX_NAV_VELECEF_I2C
Sensors:519:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C, settings.sensor_uBlox.logUBXNAVVELNED); // CFG-MSGOUT-UBX_NAV_VELNED_I2C
Sensors:520:45: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C, settings.sensor_uBlox.logUBXRXMSFRBX); // CFG-MSGOUT-UBX_RXM_SFRBX_I2C
Sensors:521:46: error: 'UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C' was not declared in this scope
success1 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C, settings.sensor_uBlox.logUBXTIMTM2, maxWait); // CFG-MSGOUT-UBX_TIM_TM2_I2C
Sensors:526:47: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C' was not declared in this scope
success2 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C, settings.sensor_uBlox.logUBXNAVHPPOSECEF, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_HPPOSECEF_I2C
Sensors:527:48: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C' was not declared in this scope
success2 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C, settings.sensor_uBlox.logUBXNAVHPPOSLLH, maxWait); // CFG-MSGOUT-UBX_NAV_HPPOSLLH_I2C
Sensors:533:40: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C' was not declared in this scope
success3 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C, settings.sensor_uBlox.logUBXNAVRELPOSNED, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_NAV_RELPOSNED_I2C
Sensors:539:40: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C' was not declared in this scope
success4 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C, settings.sensor_uBlox.logUBXRXMRAWX, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_RXM_RAWX_I2C
Sensors:545:40: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C' was not declared in this scope
success5 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C, settings.sensor_uBlox.logUBXNAVATT, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_NAV_ATT_I2C
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'uint8_t enableConstellations(uint16_t)':
Sensors:570:44: error: 'UBLOX_CFG_SIGNAL_GPS_ENA' was not declared in this scope
success &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_SIGNAL_GPS_ENA, settings.sensor_uBlox.enableGPS, VAL_LAYER_RAM); //CFG-SIGNAL-GPS_ENA : Enable GPS (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:570:44: note: suggested alternative: 'UBX_MGA_GPS_EPH'
UBX_MGA_GPS_EPH
Sensors:571:44: error: 'UBLOX_CFG_SIGNAL_GLO_ENA' was not declared in this scope
success &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_SIGNAL_GLO_ENA, settings.sensor_uBlox.enableGLO); //CFG-SIGNAL-GLO_ENA : Enable GLONASS
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:571:44: note: suggested alternative: 'UBX_MGA_GLO_EPH'
UBX_MGA_GLO_EPH
Sensors:572:44: error: 'UBLOX_CFG_SIGNAL_GAL_ENA' was not declared in this scope
success &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_SIGNAL_GAL_ENA, settings.sensor_uBlox.enableGAL); //CFG-SIGNAL-GAL_ENA : Enable Galileo
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:572:44: note: suggested alternative: 'UBX_MGA_GAL_EPH'
UBX_MGA_GAL_EPH
Sensors:573:44: error: 'UBLOX_CFG_SIGNAL_BDS_ENA' was not declared in this scope
success &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_SIGNAL_BDS_ENA, settings.sensor_uBlox.enableBDS); //CFG-SIGNAL-BDS_ENA : Enable BeiDou
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:573:44: note: suggested alternative: 'UBX_MGA_BDS_EPH'
UBX_MGA_BDS_EPH
Sensors:574:45: error: 'UBLOX_CFG_SIGNAL_QZSS_ENA' was not declared in this scope
success &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_SIGNAL_QZSS_ENA, settings.sensor_uBlox.enableQZSS, maxWait); //CFG-SIGNAL-QZSS_ENA : Enable QZSS (maxWait 2100 ms)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:574:45: note: suggested alternative: 'UBX_MGA_QZSS_EPH'
UBX_MGA_QZSS_EPH
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\storeData.ino: In function 'bool storeData()':
storeData:183:60: error: 'class SFE_UBLOX_GPS' has no member named 'getI2CTransactionSize'
uint16_t maxTransaction = (uint16_t)(gpsSensor_ublox.getI2CTransactionSize());
Multiple libraries were found for "SdFat.h"
Used: C:\Users\User\Documents\Arduino\libraries\SdFat
Not used: C:\Users\User\Documents\Arduino\libraries\SdFat_-_Adafruit_Fork
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
