- Mon Nov 07, 2005 9:40 am
#7752
Hello experts,
I am a newbe and proud owner of the olimex developer board AT91SAM7-P64-A with AT91SAM7S64-Chip.
I have a XP, an USB-cable and the Board.
Believing the ATMEL-Introduction
of the SAM-BA application, I have following to do in order to upload a
test-file into the controller: execute the SAM-BA-Boot procedure (
1. Power down the AT91SAM7-P64
2. Close the Jumper2 named TST
3. Power up the AT91SAM7-P64
4. Wait 10s
5. Power down the AT91SAM7-P64
6. Remove the Jumper2 named TST
7. Power up the AT91SAM7-P64,
connect the PC with the USB-Connector of the target and start SAM-BA V1.7. I selected a Test-File (the USB-Device-bin), (leave the COM1 parameter unthouched).
Then i click USB-Connection and SAM-BA should detect the Board automaticaly.
SAM-BA shows the Error-Message '-E- DEVICE NOT FOUND on USB !'.
Is my Board defect?
I also tried to connect the bard via the JTEG<->Parallel-Port - cable, and insert 'LPT1' instead of
'COM1' (I actually have no COM-Port on my PC) - It doen't work too.
My Board has the 18342-Quarz, so USB should work. While inserting the
Board on USB, Windows detects the Board as 'atm6124.Sys.ATMEL AT91xxxx Test Board'.
Makes it a difference if I use an external 6V or only the USB-Cable-Voltage? I did do the recovery-procedure by using the
external power supply, without connected USB-Cable.
Do I need a special JTEG-USB (ICE or so..)?
The Documentations could be longer with more information with a
'Step-by-Step' Introduction for the eager newbie!
Could anybody help me?
(BTW: SAM-Proc also not connects!)
txh
4. Wait 10s
Is my Board defect?
txh
