- Thu Nov 29, 2018 8:09 am
#201231
i want to design a tiny 3mm thick PCB and since it is super expensive (170$ for 10pcs) to order 3mm thick PCBs, i'm wanted to ask advice on what people with experience think of this design and what issues i might run into.
the board is super simple - basically a breakout for a mini Neopixel (SK6812MINI) where the LED is mounted at one end and the grooves are the 4 Pins (+,-,Din, Dout). shrink-tube is used to couple a 2mm diameter sideglow optic fiber in front of the LED. and conductive thread is used to sew the contacts to the plated half-via groves.
here some photos of my handmade prototypes:
here a rough sketch:
here the dimensions i have in mind:
questions:
- what could be issues with milling such small boards?
- if the narrowest part of the 3mm thick board is 1.5mm wide, does this become a weak point or is the FR4 strong enough, especially since it will be a plated via at that point?
- in order to minimize waste, could it be possible to layout the boards as illustrated above so that two boards share the same plated via?
- any tips on PCB manufacturing services that do 3mm thick PCBs in small quantities? seeed studio costs 170$ for 10pcs.
thanks!
hannah
// more photos here: https://www.flickr.com/photos/plusea/al ... 1569545895)
// more documentation here:
http://www.kobakant.at/KOBA/category/lulu/
https://github.com/eTextile/Lulu
questions:
thanks!
hannah
