- Fri Sep 27, 2013 3:37 pm
#163939
The purpose of this simple DIY project is to build an electronic circuit that received the GPS time signal, convert it to the radio-controlled clock format, and transmit that signal to the clock. Once built, there is no need for setup and maintenance, all you need is put this unit close to the window to receive GPS signal, and it will transmit the time signal to your radio-controlled clock.
http://sourceforge.net/projects/gpstora ... lledclock/
