- Wed May 08, 2013 11:46 am
#159290
I am trying to integrate an ADH8066 with an Arduino (I am eventually planning on making my own board using the arduino bootloader on an ATMEGA32U4). The problem is, the ADH8066 uses 4V while the Arduino typically is set up to use 5V. My questions is, can I run an Arduino at 4V 16MHz to avoid using two different voltages on my board? Thanks for any input!
