This is the gps data logger that I designed just recently. I just got the first one assembled. The EM406 gps uses the latest SIRFSTAR III chipset to make sure you get a signal in areas of dense foliage, canyons, and even inside buildings depending on the construction technique. Battery is a 3.6V lithium ion type large enough to provide 22 hours of continuous operation and can be replaced with a fresh battery or charged/powered via a usb port at 100mA. The SD memory card can be as large as 2GB and up to 255 files can be on the card at a time. The time and date of each file is also recorded when the file is created and updated. Recording options allow for direct recording of NMEA output from the gps or processed data in the form of LAT,LON,ALT,HDG,SPD,SAT,FIX,Hours,SD_Minutes,SD_Se conds,SD_Day,SD_Month,SD_Year. Either option is configurable via a CONFIG.TXT file. The contents of this file are below.
4800,1,11111111
‘BAUD,INTERVAL,OPTIONS
‘BAUD OPTIONS (1200,2400,4800,9600,19200,38400)
‘INTERVAL OPTIONS (0-65536) SECONDS
‘NMEA MODE[7]=0 (MODE[7] NC[6] GPVTG[5] GPRMC[4] GPGSV[3] GPGSA[2] GPGLL[1] GPGGA[0])
‘KML MODE[7]=1 (MODE[7] LAT/LONG[6] ALT[5] HDG[4] SPD[3] SAT[2] FIX[1] TIME/DATE[0])
‘BIT[X]=0=OFF BIT[X]=1=ON
The first line is what actually configures the device. You set the baud rate (communication setting), recording time in seconds, and finally a 1 (on) or 0 (off) for the options of the two different recording methods. It’s really easier than it seems. The device defaults to the setup you currently see. You can “tweakâ€
Regards Ryan
$25 SMT Kapton Stencils -
http://www.ohararp.com/
US Distributor of PDS -
http://www.ohararp.com/compilers.html
