- Sun Jul 16, 2023 9:15 pm
#242592
I am trying to reconfigure TXRX such that Serial1 TX RX is through D8 and D9 - assigned as qwicc SCL and SDA by default. I thought i could do this easily by modifying configureSerial1TxRx() like below:
void configureSerial1TxRx(void) // Configure pins 8 and 9 for UART1 TX and RX
am_hal_gpio_pincfg_t pinConfigTx = g_AM_BSP_GPIO_COM_UART_TX;
pinConfigTx.uFuncSel = AM_HAL_PIN_8_UART1TX;
pin_config(PinName(BREAKOUT_PIN_TX), pinConfigTx);
am_hal_gpio_pincfg_t pinConfigRx = g_AM_BSP_GPIO_COM_UART_RX;
pinConfigRx.uFuncSel = AM_HAL_PIN_9_UART1RX;
pinConfigRx.ePullup = AM_HAL_GPIO_PIN_PULLUP_WEAK; // Put a weak pull-up on the Rx pin
pin_config(PinName(BREAKOUT_PIN_RX), pinConfigRx);
also
const byte BREAKOUT_PIN_TX = 8;
const byte BREAKOUT_PIN_RX = 9;
and finally
commented out
//TwoWire qwiic(PIN_QWIIC_SDA,PIN_QWIIC_SCL); //Will use pads 8/9
Please let me know if i am missing something.
Thank you for your help.
Hj
also
and finally
commented out
Hj
