- Mon May 15, 2023 4:30 am
#241088
I use Artemis with NEO-M9N Qwiic GPS at a 25 Hz required frequency (using a special firmware from you).
The record appears to be closed to that, at 22Hz.
As I need to record other Qwiic data at higher rate, I tried to record internal IMU data at 100 Hz without and with this GPS.
Then, when recording GPS also, the record appears limited approximately to 13Hz as if the GPS imposed the frequency (the IMU data are merged with GPS data).
Could you tell me if it is possible to separate data messages in order to get other Qwiic data at higher frequency that the GPS this one or other ?
Regards
Christian
Regards
Christian
