- Tue Mar 04, 2008 2:57 pm
#44018
I set up my KLP circuit as described in the KLP walkthrough. I have a PIC uC sending out a constant string "Test" and have the receiver end connected to a MAX232 chip which connects to a PC running hyperterminal.
If I connect the TX line of the uC directly to the MAX232 I get the "Test" string over and over (with a 0.5s delay between each transmission of the string "Test").
Now I put the RF modules in between. I'm not sure what capacitors to add if any, so I put some between ground and Vcc as is my usual practice. When I hit "reset" on my uC, I get one clear "Test" string output on hyperterminal followed by a lot of garbage. When I hit reset again I get the "Test" string once followed by garbage again, I have the devices about 5ft apart, will try seperating them further tonight (not enough room in my office to spread them out further lol). Below is a sample output, you can see where I hit reset over and over to get a bunch of "Test" strings in a row, that's how it should look w/o me pressing reset.
Any clues how to make this better? I made a helical antenna for the transmitting end out of 22AWG wire, 15 turns with about 3mm diameter which seemed to help (I wasn't even getting a single "Test" transmission w/o it, just garbage).
TestTestTestTestTestTestTestTestTestTestTestTestTestTestTestTestTestTes
tTestTestTestTestTestTestTestTestTest(óúÄúú³úvúú%Äú ^ úÄúãúp³úðð ÄúúúÄ
œMúðúðúã{> œãÄòV7ãú%ú{Qð ³ úœ³ðúTest#MQMQVestHTestTe
stððœúððúúððúððúúðúúúúúúúðúúúúúúúðð³ |*^³úðBTVestUestTestT
estTestœDã 9úijœ
úúø óG G8óÄ´ú9@ð´œ@ú@Äq³púðÄNú`ÄÄð`@ú`Ä
ð@@³ú@œúN³±Äú ð`@ÄúÃÄ`bt``Ä ±úbtpÄNÄ` úl úbt ú``úP ú`úP ú`úú
``tP ú bt @@tø±@@± ±@AH`@@@`ú !±@
@Ä@` úD@@A@t ` ±@± H(@@A@@@@ @
±@@@P@A@@@ú !@D
estTestœDã 9úijœ
±@@@P@A@@@ú !@D
