- Thu Jan 03, 2008 4:13 am
#40356
I actually get headache trying to make my robot work with bluesmirf module ... well I know it will not be as easy as in the tutorial so I hope know to find some help.
Actually, i am able to pair correctly the bluesmirf module with bluesoleil (in evaluation mode with my dongle). When i connect to it, the red led is lighting.
Then when i am sending command (lynxmotion lynxterm soft) through my new virtual com port, the scc32 seems to receive it (led flashing) but I never get a response.
I'm working under windows XP, i have tried also to use default com port binding (SPP) but the result is the same. Also under Vista i get the same result ...
I wonder if the command are sent properly but don't know how to workaround this problem to solve it.
Any help will be appreciated
Regards,
Cedric
Regards,
Cedric
