- Fri Dec 28, 2007 12:15 pm
#40050
I am thinking of building a bluetooth controlled robot and I have a couple of questions which I could not seem to find.
1. Can the BGB203 (sku #WRL-08461) be used as both master and slave ?
There may or may not be using a PC as I want the robot(s) to transmit data to a master controller (could be a remote control, or just a a board with an gLCD on it). So essentially, if I have 2 of these modules, would I be ok for data transfer or would I need to have a host controller somewhere that will be able to control 2 of these modules ?
2. Is video transmision possible with this module ?
There will be a camera mounted on the robot and at times will want to send a short stream. Could be 5-10s maybe even less. Or if that is not possible, it can take a picture every so many seconds and transmit the picture instead.
That is all the important questions i have at this moment, but there may be furthur ones depending on the answers to the above questions.
Thanks in advance !
Thanks in advance !
