- Wed Sep 12, 2007 7:39 am
#35037
Hi guys.
I have a question about the configuration of the nRF 2401A.
On the Demo Code that Sparkfun gives the configuration is:
23: 0 Payloads have an 8 bit address
22: 0
21: 1
20: 0
19: 0
18: 0
17: 1 16-Bit CRC
16: 1 CRC Enabled
15: 0 One channel receive
14: 1 ShockBurst Mode
13: 0 250K Transmission Rate
12: 0
11: 1
10: 1
9: 1 RF Output Power
8: 0 RF Output Power
7: 0 Channel select (channel 2)
6: 0
5: 0
4: 0
3: 0
2: 1
1: 0
0: 0 Transmit mode
The part that i am interrested in is:
22: 0
21: 1
20: 0
19: 0
18: 0
17: 1 16-Bit CRC
16: 1 CRC Enabled
Now here the payload is set to 8 bits (1 byte)
But thurther down the code the Transmission and Reception output 4 bytes:
//Erase the current data array so that we know we are looking at actual received data
data_array[0] = 0x00;
data_array[1] = 0x00;
data_array[2] = 0x00;
data_array[3] = 0x00;
//Clock in data, we are setup for 32-bit payloads
for(i = 0 ; i < 4 ; i++) //4 bytes
for(j = 0 ; j < 8 ; j++) //8 bits each
temp <<= 1;
temp.0 = DATA1;
CLK1 = 1;
CLK1 = 0;
data_array = temp; //Store this byte
But the configuration is set up for 8 bit payload and not 32.
am i correct here?
So basicly the Cycle of 4 bytes is unnessesary since only the first byte is sent.
Is this correct ?
22: 0
21: 1
20: 0
19: 0
18: 0
17: 1 16-Bit CRC
16: 1 CRC Enabled
12: 0
11: 1
10: 1
6: 0
5: 0
4: 0
3: 0
2: 1
1: 0
0: 0 Transmit mode
22: 0
21: 1
20: 0
19: 0
18: 0
17: 1 16-Bit CRC
16: 1 CRC Enabled
temp <<= 1;
temp.0 = DATA1;
CLK1 = 1;
CLK1 = 0;
am i correct here?
Is this correct ?
Never stop learning!
--Dimka--
--Dimka--
