- Fri Aug 03, 2007 5:44 am
#33265
I bought a bluetooth module from sparkfun, "Bluetooth v2.0 SMD Module
SKU#: WRL-00149", and I am having some problems getting it to work properly. Its mounted on a PCB receiving UART from an AT91SAM7S256.
On the PC end I am using a bluetooth dongle with bluesoleil. I can see the device on the computer and connect and create a com port between the two. From hyperterminal I can send various commands and receive back the appropriate responses (+++ etc)
The problem is however I cannot get my UART from the ARM to go through the Bluetooth module and show up on my computer. I have checked the UART with a scope and it is definitely getting to the module. I have double checked my baud rate and parity settings too.
Is there some special mode I have to set the module to? Can anyone think of anything I could possibly be missing? Also any suggestions as to a good replacement for hyper terminal?
Thanks in advance,
David
Thanks in advance,
David
