- Fri Aug 03, 2007 1:30 am
#33261
I need a Parallel port. My laptop does not have a parallel port nor a free PCMCIA slot. Does anyone know of a USB to Parallel Port that works in true ECP/EPP mode? All USB to Parallel Port cables I have found are for printers only. I would like to be able to bit-bang the parallel port and these printer only cables do not work for this.
The USB to Parallel Port needs to be completely transparent in Windows. I should be able to plug it into the USB port and have a LPT port available.
I am connecting the Parallel Port to a custom device that is bit-banged. I can not change the Windows software nor the custom device (hardware or firmware).
I have seen that FTDI has a USB to Parallel Port chip FT245R but I do not know if it truly supports what I need. The application note has a "bit-bang" mode. Anyone have any experience with this chip?
Any info would be greatly appreciated.
Thanks,
Nullz
Thanks,
Nullz
