By stevef
#31807
hi all,
does anyone know the solution to this little problem :?:
I got a USB Eval Board with a GPS reciever, i used IQ_Monitor to change the Trimble Lassen IQ reciever to RTMC-IN/NMEA-out, thinking
that when i pulled the battery it would reset to factory setting, but it doesn't :shock: anyone got a simple solution?
cheers :wink:
By gm
#31855
Was it port 1 and did you save the configuration to flash? If so, I think you are hosed. I could not find anything in the manual that would allow you to reset it to factory defaults if you are unable to communicate with it. You might try contacting Trimble directly.
Greg
