Help with CCS and Tiny or Screemer Bootloader's
forrequi
Post by forrequi » Tue Mar 20, 2007 6:25 am
Good day. ':D'
Can anyone help me with the C code that have to be used to implement a 16F877A bootloading capable C code? I found that the code look's like:
//For 18F2550
#build(reset=0x1, interrupt=0x8)
#ORG 0x0F00,0x0FFF {}
// For 16F88
#build(reset=0x1, interrupt=0x5)
The code for 16F877A look like the code above, or no?
// For 16F877A
#build(reset=0x1, interrupt=0x4)
Thank's
Wufkodabi
CCS C and Bloader / Screamer boot loader
Post by Wufkodabi » Tue May 15, 2007 4:23 am
Hi forrequi!
I am using the following code:
#include <16F877A.h>
#fuses NOWDT, XT, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NOWRT
//  next two statements are to set the program offset for BLOADER to work
#org 0x1F00, 0x1FFF{}                    // for the 16f877
#build(reset=0x4)
void main() {...
Works for me with Bloader v1.4 and Screamer v1.6. My PIC was programmed with the Bloader-877A-4MHz.hex bloader. My CCS C version is PCWH v4.013.
Here is a blink-a-led for you to test:
#build(reset=0x4)
#use delay (clock=4000000)
void main(void) {
   while(1) {
      Output_high(PIN_B0);
      delay_ms(1000);
      Output_low(PIN_B0);
      delay_ms(1000);
Hope this works. I am a beginner with PICs myself, and it is not easy to get started. I must say Bloader/Screamer does make it easier. Good luck!
d.
Wufkodabi
Post by Wufkodabi » Wed Jun 06, 2007 9:19 am
#build(reset=0x4)
I just noticed that, while they worked for my previous programs, these statements give an "invalid org range" error when you use them with interrupts:
"Attempted to create: 00004-00032 for ISR
Invalid ORG range"
I am trying to get a program that uses timer0 to compile, while keeping support for the Bloader boot loader.
I suspect that the interrupt vector somehow gets screwed up. I tried the following as well:
#build(reset=0x4,interrupt=0x4)
Same error. I don't have a firm grasp of the memory organistion of the 16F877A, nor of the ORG and build commands, so I am a bit stuck. Anyone can offer some help?
This is my test code. It is mostly copied right of the web, and is supposed to be working. Ofcourse I added the ORG and build commands to support my boot loader.
//  next two statements are to set the program offset for BLOADER to work (from CCS website)
#use delay(clock=4000000)                                                       //set clock base for delay_ms and delay_µs functions
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)                                 //set hardware UART speed and pins
// define more sensible names for pin functions
#define LED1   PIN_A1
#define LED2   PIN_A2
#define HIGH_START 255
byte seconds, high_count;
#INT_RTCC
void clock_isr() {
   if(--high_count==0) {
      printf("+");
//      output_high(LED1);
//      delay_us(5);
//      output_low(LED1);
      high_count=HIGH_START;
void main() {
   set_rtcc(0);
   setup_counters(RTCC_INTERNAL, RTCC_DIV_128);
   enable_interrupts(INT_RTCC);
   enable_interrupts(GLOBAL);
   while(TRUE) {
      printf(" -%2X", high_count);
      delay_ms(10);
Skolnik
Re: Help with CCS and Tiny or Screemer Bootloader's
Post by Skolnik » Thu Apr 22, 2010 5:01 am
Try this:
#build(reset=0x4,interrupt=0x8 )
#ORG 0x0f00,0x0fff {}
