- Fri Feb 16, 2007 8:24 am
#26183
I have a prototype built around the Telit gm682 module with GSM and GPS. I plan to use internal antennas (in a plastic box), but would like to be able to support external antennas as well.
I don't need to have both active at the same time, but would like to programatically switch between them. This implies I would have a software-controlled analog switch or relay to route the correct antenna signal to the gm682 module.
Does anyone know if this is feasible? Would the switch degrade the signal quality too much? And would this pass muster with the FCC if we ever needed to certify the antenna circuitry?
Also, if anyone has taken a product to market using the Telit module, I'd be very interested in hearing your experiences.
Regards,
Brett
Regards,
Brett
