Open source ARM Debugger
By armdeveloper
#25593
I am getting errors in my gdb session connected to oocd as follows. Why is this happening ?
arm-elf-gdb
GNU gdb 6.5.0.20060626-cvs
Copyright (C) 2006 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "--host=i686-pc-linux-gnu --target=arm-elf".
(gdb) file main.elf
Reading symbols from .../main.elf...done.
(gdb) break main
Breakpoint 1 at 0x240: file main.c, line 69.
(gdb) target remote localhost:3333
Remote debugging using localhost:3333
warning: (Internal error: pc 0x10 in read in psymtab, but not in symtab.)
_boot () at crt0.S:44
44 ldr pc,_dabt // data abort - _dabt
Current language: auto; currently asm
(gdb)
By armdeveloper
#25596
It looks like its a bug with gdb for sections that start at zero, as this post describes.
http://www.cygwin.com/ml/gdb/2006-11/msg00051.html
I am going to post this to the gnu-arm mailing list and see what they have to say.
By armdeveloper
#25606
OK, I fixed the problem.
For those of you that might run into this, here is what I did.
I found this post that explained the problem was gdb throwing out a section that it thought might be bogus.
http://sourceware.org/ml/gdb/2006-06/msg00123.html
Like the author of that post, I commented out the line
if (low == 0 && (bfd_get_file_flags (obfd) & HAS_RELOC) == 0) > return 0;
in file ./gdb/dwarf2read.c (from the Insight directory that I used to build arm-elf-gdb from.
I then did a make clean followed by a make all and make install.
I then ran arm-elf-gdb exactly as before and it works.
