- Tue Jan 23, 2007 6:57 am
#25327
This is a bit long, but hopefully someone can tell me what I'm doing wrong. At this point I believe the module to be bad but any suggestions would be appreciated.
First, using my own serial port code in Linux, I was unable to receive a
response from the device. I opened the serial port, sent the "AT"
command and then the system blocked on a call to read() while
waiting for a response.
Next, via Minicom in Linux, I opened a connection to the device, but
failed to receive a response to the "AT" command (or any other
command).
Finally, I switched over to Windows and duplicated the procedure in
their guide that was on the website and I had the same result. After
sending the "AT" command -- or any other command, I failed to receive a response.
I powered down the device between each attempt but was still unable to receive a response.
I tried all of the above both with a SIM card in the modem and without a
SIM card.
Any help would be appreciated.
command).
SIM card.
