- Sat Apr 03, 2021 9:02 am
#224681
I have an ESP-32 module in a Weather Carrier board. So far, I have not been able to run even the simplest example sketch. After figuring out that I have to hold the boot button to connect (and asking myself why this is even a thing and why is it not mentioned anywhere in the setup page), I am now stuck on the "Leaving... Hard Resetting Via RTS Pin" rabbit hole.
I followed the directions and am still unable to run a sketch on my device. I've uploaded screenshots of the IDE Board settings as well as the output of the upload process.
I have successfully used MCU boards to send data via MQTT over Wifi, so I'm pretty confident that my toolset is working.
Please advise.
Please advise.
