#228490
I too am having a similar issue with a board brand new out of the box.
Initialization text is:
No config file found. Using settings from EEPROM.
Artemis OpenLog v2.0
Logging to: dataLog00008.TXT
Finding the next available log file.
This could take a long time if the SD card contains many existing log files.
Logging to: serialLog00000.TXT
ICM-20948 failed to init.
SD card online
Data logging online
Serial logging online
IMU offline
I've tried several different binaries, settling finally on V2.0. All reported the ICM-20948 failed to init. I've increased and decreased the baud rate to no avail as suggested earlier in this thread. Any other suggestions?
#228503
Confirmed, I am using OpenLog_Artemis-V10-v20.bin as the version when I wrote the original post. I have reloaded it to make sure and the problem persists - and it does.
The conclusion of the reload dialog follows:
Sending frame #176, length: 880
Got frame request
Upload complete!
Nominal bootload 9732.98 bytes/sec
#245860
Is there any other fix until now?
I tried even the never .bin version (OpenLog_Artemis-V10-v25.bin) but get the same error
Logging to: dataLog00026.TXT
SD card online
Data logging online
IMU offline
Identifying Qwiic Muxes...
Identifying Qwiic Devices...
No Qwiic devices detected
rtcDate,rtcTime,output_Hz,
01/01/2000,00:22:58.76,0.0,
01/01/2000,00:22:58.86,20.0,
01/01/2000,00:22:58.96,15.0,
01/01/2000,00:22:59.06,13.333,
01/01/2000,00:22:59.16,12.500,
 Topic permissions
