By TickTockTony
#203422
I have an output from a magnetic sensor coil. Its a sign wave pulse voltage of + - 200mv. That's too small to trigger a transistor. What device would you recommend to sense the pulse?
Thanks in advance for your time.
By TS-Chris
#203452
200mv is plenty large a signal for most any transistor.
You either need a different transistor or to cascade the transistors you're using now in a darlington configuration to further amplify the output.
Another option would be to use an op-amp.
