Open source ARM Debugger
By markkang
#200836
Here is the config:
interface ftdi
ftdi_device_desc "USB <-> Serial Converter"
ftdi_vid_pid 0x0403 0x6014
ftdi_layout_init 0x0008 0x008b
ftdi_layout_signal nTRST -data 0x0100 -oe 0x0100
ftdi_layout_signal nSRST -data 0x0200 -oe 0x0200
reset_config none
ftdi_tdo_sample_edge falling
adapter_khz 25000
transport select jtag
jtag newtap 1SG280L tap -expected-id 0xC32150DD -irlen 10
Here is the output log:
RUNTEST 100000 TCK;
RUNTEST 100000 TCK;
SIR 10 TDI (201);
RUNTEST 16 TCK;
SDR 34 TDI (100002038)
Error: tdo check error at line 407
Error: READ = 0x000000000
Error: WANT = 0x000000003
Error: MASK = 0x3fdfffffd
Error: fail to run command at line 15981
Error tdo check error at line 407
Time used: XmXXsXXXms
svf file programmed failed
