Odd mills behavior
messar
Odd mills behavior
Post by messar » Thu Oct 18, 2018 7:04 pm
I am working with a nRF52832 breakout board, and trying to use mills() to time a 30 minute event. Surprisingly, I looks like I'm running into some type of rollover at 512 seconds.
The following code:
#include <Wire.h>
void setup()
Serial.begin(9600);
Wire.begin();
void loop()
  Serial.println(millis())
GIves this every time I run. (abbreviated)
511974
511983
511991
511999
8
11
15
19
23
Any help would be appreciated on what needs to change to avoid this.
Thanks,
matt
jremington
Re: Odd mills behavior
Post by jremington » Fri Oct 19, 2018 7:58 am
That code won't compile, so it isn't what you were running.
messar
Post by messar » Fri Oct 19, 2018 8:53 am
Thanks for catching the error - missing a ;
Here is the corrected code:
#include <Wire.h>
void setup()
Serial.begin(9600);
Wire.begin();
void loop()
  Serial.println(millis());
