- Thu Jul 13, 2017 8:13 am
#195551
I am trying to create a sensor to detect if a Window AC unit is running. I'm currently trying to use a piezo film sensor hooked up to the ADC of the esp8266. I know that the piezo is capable of generating voltage much greater than the 1V that the esp8266 can handle, however, in my testing, I'm not seeing values above 120 mv, so I think I'm okay for now. But my problem is that the readers are not granular enough. When the AC is off I'm getting about 20mv, when it's on I'm getting betweeen 50-150 mv. Not much room for error between 20-50 mv.
Currently the piezo film sensor is hooked directly to ground and the ADC pin of the esp8266. I know most tutorials suggest a simple 1 Ohm resistor across the sensor's pins to bring down voltages to ranges inside 1V, but when I do that, the reading when the AC unit is on is so low, there's even less discrimination between AC on and AC off in sensor values.
Is there a way to amplify the output of the piezo film, while clamping it's max to 1V?
Or can you think of a better way to detect if the window AC is on?
Design Goals:
Design Goals:
- As simple of a design as possible
- As cheap of a design as possible
- Low power, running from LiPo
- No modifications needed to the AC unit itself
