- Mon Jun 12, 2017 10:47 am
#195153
I'm building a controller for an art show. There are 21 arcade buttons, connected to pins 0-20 on a teensy 3.5 board. Each pin is assigned to a letter, going in order through the alphabet: 0 - a, 1 - b, 2 - c.... 20 - u. Using Java in Processing, we have each letter performing different functions, pressing two buttons will also have a different function. When tested without the Teensy controller, the two key presses works perfectly, but when we plugged the controller in, it doesn't. It behaves as if the two buttons were pushed at separate times, and not together.
Any feedback is appreciated, thank you!
