- Sun May 07, 2017 5:45 am
#194715
I am using the WavTrigger to play drums sequenced from Cubase.
I currently have two different drum sets loaded to the WavTrigger (shown below) I placed switches on trigger 1 and trigger 2 and then set them to Midi bank up and Midi bank down(code below).
The first set of drums plays fine but when I press bank up the mapping of the second set is all wrong instead of the kick being on C1 it slides down the scale to G#-2 and maps the sounds starting from that note. Am I missing something really simple, this is driving me nuts!
Any help appreciated cheers
Bank one:
036_kick.wav
037_rimshot.wav
039_clap.wav
040_snare.wav
Bank two:
136_kick.wav
137_rimshot.wav
139_clap.wav
140_snare.wav
#MIDI 1
#TRIG 01, 1, 0, 1, 1, 1, 10, 0, ,
#TRIG 02, 1, 0, 1, 1, 1, 11, 0, ,
This file was generated by the WAV Trigger Init File Maker v1.20
It is only required if you wish to over-ride default settings. You
may add your own comments below this line -->
Bank one:
036_kick.wav
037_rimshot.wav
039_clap.wav
040_snare.wav
Bank two:
136_kick.wav
137_rimshot.wav
139_clap.wav
140_snare.wav
#MIDI 1
