Everything pertaining to the data.sparkfun.com service, the phant project which powers it, and user projects which talk to the service.
By LukasCZE
#194505
I am runnig my Thermometer few weeks on Phant at data.sporkfun.com but I am having problems since yesterday. Do you also find service sometimes offline? or overloaded, idk.
Not sure if there is a problem on my side or not.
For example https://data.sparkfun.com/streams/6JZbNolApzF4om2l9yYK doesnt work. Its example stream from https://learn.sparkfun.com/tutorials/pu ... net-shield .
I get:
502 Bad Gateway
The server returned an invalid or incomplete response.
Denote that now I am not at home but in library.
Thx
Lukas
By LukasCZE
#194530
but still... sometimes i obtain
HTTP/1.0 502 Bad Gateway
Cache-Control: no-cache
Connection: close
Content-Type: text/html
<html><body><h1>502 Bad Gateway</h1>
</body></html>
denote that X-Rate-Limit-Remaining is 297 right beforehand
do you experience this issue as well?
By LukasCZE
#194537
so maybe someone else...?
sometimes i obtain
HTTP/1.1 200 OK
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET,POST,DELETE
Access-Control-Allow-Headers: X-Requested-With, Phant-Private-Key
Content-Type: text/plain
X-Rate-Limit-Limit: 300
X-Rate-Limit-Remaining: 296
X-Rate-Limit-Reset: 1493205040.307
Date: Wed, 26 Apr 2017 11:01:13 GMT
Connection: close
Transfer-Encoding: chunked
Set-Cookie: SERVERID=; Expires=Thu, 01-Jan-1970 00:00:01 GMT; path=/
Cache-control: private
but sometime
Connection: close
</body></html>
By mage2
#194858
just started using the service today, or trying to.
I am also getting the gateway error. After a few tries it seems to get through.
also having a hard time getting analog.io to import a stream from data.sparkfun.com
will open a new thread on that though
