Here is the function I am using to grab the orientation from the sensor:
Code: Select allvoid HMC6343_Compass::findOrientation() {
char tx[1];
char rx[6];
tx[0] = HMC6343_GET_HEADING_DATA;
i2c_->write((HMC6343_I2C_ADDRESS << 1) & 0xFE, tx, 1);
wait_ms(1);
i2c_->read((HMC6343_I2C_ADDRESS << 1) | 0x01, rx, 6, true);
h = ((((int)rx[0] << 8) | (int)rx[1]));
r = ((((int)rx[4] << 8) | (int)rx[5]));
p = ((((int)rx[2] << 8) | (int)rx[3]));
heading = (float)h / 10;
roll = (float)r / 10;
pitch = (float)p / 10;
That is probably the critical section but here is the whole cpp file from the library I am using:
Code: Select all/**
* @author Aaron Berk
* @author Serge Sozonoff
* Partially based on the work of Aaron Berk for the HMC6352
* @section LICENSE
* Copyright (c) 2010 ARM Limited
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
* THE SOFTWARE.
* @section DESCRIPTION
* Honeywell HMC6343 tilt compensated digital compass.
* Datasheet:
* http://www.ssec.honeywell.com/magnetic/datasheets/HMC6343.pdf
* Includes
#include "HMC6343_Compass.h"
template<class TYPE> inline TYPE BIT(const TYPE & x) {
return TYPE(1) << x;
template<class TYPE> inline bool IsBitSet(const TYPE & x, const TYPE & y) {
return 0 != (x & y);
HMC6343_Compass::HMC6343_Compass(PinName sda, PinName scl) {
i2c_ = new I2C(sda, scl);
i2c_->frequency(100000);
operationMode_ = getOpMode();
HMC6343_Compass::HMC6343_Compass(I2C& p_i2c) : i2c_(&p_i2c) {
char tx[1];
char rx[6];
wait_ms(1);
float HMC6343_Compass::getHeading() {
return heading;
float HMC6343_Compass::getRoll() {
return roll;
float HMC6343_Compass::getPitch() {
return pitch;
void HMC6343_Compass::setReset(void) {
char tx[1];
tx[0] = HMC6343_RESET;
wait_ms(500);
void HMC6343_Compass::setCalibrationMode(int exitOrEnter) {
char tx[1];
int delay = 0;
tx[0] = exitOrEnter;
if (exitOrEnter == HMC6343_EXIT_CALIB) {
delay = 50;
} else if (exitOrEnter == HMC6343_ENTER_CALIB) {
delay = 1;
wait_ms(delay);
int HMC6343_Compass::getSlaveAddress(void) {
return readEeprom(HMC6343_SLAVE_ADDR);
int HMC6343_Compass::getOffset(int axis) {
char rx[2] = {0x00, 0x00};
if (axis == HMC6343_X_AXIS) {
rx[0] = readEeprom(HMC6343_XOFFSET_MSB);
rx[1] = readEeprom(HMC6343_XOFFSET_LSB);
} else if (axis == HMC6343_Y_AXIS) {
rx[0] = readEeprom(HMC6343_YOFFSET_MSB);
rx[1] = readEeprom(HMC6343_YOFFSET_LSB);
} else {
rx[0] = readEeprom(HMC6343_ZOFFSET_MSB);
rx[1] = readEeprom(HMC6343_ZOFFSET_LSB);
return ((rx[0] << 8) | (rx[1]));
char HMC6343_Compass::getMeasurementRate() {
if (IsBitSet(operationMode_, HMC6343_CM_MR_10HZ) && !IsBitSet(operationMode_, HMC6343_CM_MR_5HZ)) { return 10; }
else if (IsBitSet(operationMode_, HMC6343_CM_MR_5HZ) && !IsBitSet(operationMode_, HMC6343_CM_MR_10HZ)) { return 5; }
else return 1;
int HMC6343_Compass::getSoftwareVersion(void) {
return readEeprom(HMC6343_SOFT_VER);
int HMC6343_Compass::getOpMode(void) {
char tx[1];
tx[0] = HMC6343_GET_OPMODE;
char rx[2];
wait_ms(1);
i2c_->read((HMC6343_I2C_ADDRESS << 1) | 0x01, rx, 2, true);
operationMode_ = (rx[1] << 8) | (rx[0]);
return operationMode_;
bool HMC6343_Compass::isOpModeFlagSet(int flag) {
return IsBitSet(operationMode_, flag);
void HMC6343_Compass::setOpMode(int opMode) {
writeShort(HMC6343_OPMOD_REG1, (short)opMode);
void HMC6343_Compass::writeShort(int lsb_address, short data) {
writeEeprom(lsb_address, data & 0x00FF);
writeEeprom(lsb_address + 1, data >> 8);
short HMC6343_Compass::readShort(int lsb_eprom_address) {
return (short)(readEeprom(lsb_eprom_address + 1) << 8) | (readEeprom(lsb_eprom_address));
void HMC6343_Compass::setMagneticDeviation(float data) {
short v;
v = (short)(data * 100); // move decimal right two places
if (v <= 1800 && v >= -1800) {
writeShort(HMC6343_DEV_LSB, v);
float HMC6343_Compass::getMagneticDeviation() {
return (float)(readShort(HMC6343_DEV_LSB)) / 100;
void HMC6343_Compass::setMagneticVariation(float data) {
short v;
writeShort(HMC6343_VAR_LSB, v);
float HMC6343_Compass::getMagneticVariation() {
return (float)(readShort(HMC6343_VAR_LSB)) / 100;
void HMC6343_Compass::setIIRFilter(short data) {
writeShort(HMC6343_IIRF_LSB, data);
short HMC6343_Compass::getIIRFilter() {
return (short)readShort(HMC6343_IIRF_LSB);
void HMC6343_Compass::setMagOffset(int axis, int offset) {
writeShort(HMC6343_XOFFSET_LSB, offset);
writeShort(HMC6343_YOFFSET_LSB, offset);
} else {
writeShort(HMC6343_ZOFFSET_LSB, offset);
int HMC6343_Compass::getMagOffset(int axis) {
return readShort(HMC6343_XOFFSET_LSB);
return readShort(HMC6343_YOFFSET_LSB);
} else {
return readShort(HMC6343_ZOFFSET_LSB);
void HMC6343_Compass::writeEeprom(int address, int data) {
char tx[3];
tx[0] = HMC6343_EEPROM_WRITE;
tx[1] = address;
tx[2] = data;
i2c_->write((HMC6343_I2C_ADDRESS << 1) & 0xFE, tx, 3, false);
wait_ms(10);
int HMC6343_Compass::readEeprom(int address) {
char tx[2];
char rx[1];
tx[0] = HMC6343_EEPROM_READ;
tx[1] = address;
i2c_->write((HMC6343_I2C_ADDRESS << 1) & 0xFE, tx, 2, false);
wait_ms(1);
i2c_->read((HMC6343_I2C_ADDRESS << 1) | 0x01, rx, 1);
wait_ms(1);
return rx[0];
And here is the h file:
Code: Select all/**
* @section LICENSE
* THE SOFTWARE.
* Honeywell HMC6343 digital compass.
* Datasheet:
#ifndef HMC6343_H
#define HMC6343_H
* Includes
#include "mbed.h"
* Defines
#define HMC6343_I2C_ADDRESS 0x32 >> 1 //7-bit address
//Commands.
#define HMC6343_EEPROM_WRITE 0xF1
#define HMC6343_EEPROM_READ 0xE1
#define HMC6343_ENTER_SLEEP 0x83
#define HMC6343_EXIT_SLEEP 0x84
#define HMC6343_ENTER_STANDBY 0x76
#define HMC6343_ENTER_RUN 0x75
#define HMC6343_RESET 0x82
#define HMC6343_ENTER_CALIB 0x71
#define HMC6343_EXIT_CALIB 0x7E
#define HMC6343_GET_ACCEL_DATA 0x40
#define HMC6343_GET_MAG_DATA 0x45
#define HMC6343_GET_HEADING_DATA 0x50
#define HMC6343_GET_TILT_DATA 0x55
#define HMC6343_SET_XFWD_PLS_ZUP 0x72
#define HMC6343_SET_XFWD_YUP 0x73
#define HMC6343_SET_ZFWD_NEG_XUP 0x74
#define HMC6343_GET_OPMODE 0x65
//EEPROM locations.
#define HMC6343_SLAVE_ADDR 0x00
#define HMC6343_OPMOD_REG1 0x04
#define HMC6343_OPMOD_REG2 0x05
#define HMC6343_SN_LSB 0x06
#define HMC6343_SN_MSB 0x07
#define HMC6343_DEV_LSB 0x0A
#define HMC6343_DEV_MSB 0x0B
#define HMC6343_VAR_LSB 0x0C
#define HMC6343_VAR_MSB 0x0D
#define HMC6343_XOFFSET_LSB 0x0E
#define HMC6343_XOFFSET_MSB 0x0F
#define HMC6343_YOFFSET_LSB 0x10
#define HMC6343_YOFFSET_MSB 0x11
#define HMC6343_ZOFFSET_LSB 0x12
#define HMC6343_ZOFFSET_MSB 0x13
#define HMC6343_IIRF_LSB 0x14
#define HMC6343_IIRF_MSB 0x15
#define HMC6343_SOFT_VER 0x02
#define HMC6343_X_AXIS 0x01
#define HMC6343_Y_AXIS 0x02
#define HMC6343_Z_AXIS 0x04
// Operation mode bit masks
// LSB
#define HMC6343_COMP 0x80
#define HMC6343_CAL 0x40
#define HMC6343_FILTER 0x20
#define HMC6343_RUN 0x10
#define HMC6343_STDBY 0x08
#define HMC6343_UF 0x04
#define HMC6343_UE 0x02
#define HMC6343_LEVEL 0x01
//Operational mode register masks.
#define HMC6343_CM_MR_1HZ 0x00
#define HMC6343_CM_MR_5HZ 0x100
#define HMC6343_CM_MR_10HZ 0x200
class HMC6343_Compass {
public:
* Constructor.
* @param sda mbed pin to use for SDA line of I2C interface.
* @param scl mbed pin to use for SCL line of I2C interface.
HMC6343_Compass(PinName sda, PinName scl);
HMC6343_Compass(I2C& p_itc);
* Sample the device and return the result.
* @return In heading output mode, the current heading as a number between
* 0-3599, representing 0-359.9 degrees.
* In raw magnetometer X output mode, the raw output of the X-axis
* magnetometer.
* In raw magnetometer Y mode, the raw output of the Y-axis
* magnetometer.
* In magnetometer X mode, the corrected output of the X-axis
* magnetometer.
* In magnetometer Y mode, the corrected output of the Y-axis
* magnetometer.
void findOrientation();
* Returns Heading
float getHeading();
* Returns Roll
float getRoll();
* Returns Pitch
float getPitch();
* Update bridge offsets.
* Performs a set/reset immediately.
void setReset(void);
* Enter into or exit from calibration mode.
* @param enterOrExit 0x45 -> Exit
* 0x43 -> Enter
void setCalibrationMode(int enterOrExit);
* Save the current operation mode byte to EEPROM.
void saveOpMode(void);
* Read the memory location on the device which contains the slave address.
* @return The slave address of the device.
int getSlaveAddress(void);
* Read the current offset for X or Y axis magnetometer.
* @param axis 0x01 -> X-axis
* 0x02 -> Y-axis
* 0x04 -> Z-axis
* @return The current offset for the axis as a 16-bit number.
int getOffset(int axis);
* Get the software version on the device.
* @return The software version number.
int getSoftwareVersion(void);
* Get the current operation mode.
* @return 0x00 -> Standby mode
* 0x01 -> Query mode
* 0x02 -> Continuous mode
int getOpMode(void);
* Set the operation mode.
* @param periodicSetReset 0x00 -> No periodic set/reset
* 0x01 -> Periodic set/reset
void setOpMode(int opMode);
void setMagneticVariation(float var);
float getMagneticVariation();
void setMagneticDeviation(float data);
float getMagneticDeviation();
bool isOpModeFlagSet(int flag);
void setIIRFilter(short data);
short getIIRFilter();
void setMagOffset(int axis, int offset);
int getMagOffset(int axis);
char getMeasurementRate();
private:
//Functions
I2C* i2c_;
int operationMode_;
* Write to EEPROM on the device.
* @param address Address to write to.
* @param data Data to write.
void writeEeprom(int address, int data);
* Read EEPROM on the device.
* @param address Address to read from.
* @return The contents of the memory address.
int readEeprom(int address);
void writeShort(int lsb_address, short data);
short readShort(int lsb_eprom_address);
//Variables
float heading;
float pitch;
float roll;
short h, r, p;
#endif /* HMC6343_H */
This library was made years ago (other than some limited modifications that I made to it) but I think it is still consistent with the datasheet.
