- Wed Mar 15, 2017 5:45 am
#193892
I am making a musical instrument using a Arduino controlling the Tsunami using midi.
https://cdn.sparkfun.com/datasheets/Wid ... rigger.pdf
I need to have a means of volume control for each of the eight outputs.
I am considering whether to alter the volume levels for each output with pots controlled by the arduino software ,or to hard wire the outputs of the Tsunami with pots/ mixer circuit.
Finally I wish to combine the eight mono audio outputs together to form a single mono line out signal.
Can you please tell me your views on the way to do this ?
Cheers Sam
Cheers Sam
