https://github.com/esp8266/Arduino/blob/master/libraries/ESP - SparkFun Electronics
Everything pertaining to the data.sparkfun.com service, the phant project which powers it, and user projects which talk to the service.
#193277
Using the above code, using my usual WiFi I get:
Connecting to Virgin Mobile 4G_38AB4B
WiFi connected
IP address:
192.168.0.132
connecting to data.sparkfun.com
Requesting URL: /input/MGXg6JxO47cj1OKAJoZr?private_key=xxx&rh=1&apssid=IOT123+tu-gro+133&temp=85.4&z1lighton=true&z2lighton=false&z1soilmoisture=50&z2soilmoisture=50&z1waterdoses=1&z2waterdoses=1
HTTP/1.1 200 OK
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET,POST,DELETE
Access-Control-Allow-Headers: X-Requested-With, Phant-Private-Key
Content-Type: text/plain
X-Rate-Limit-Limit: 300
X-Rate-Limit-Remaining: 288
X-Rate-Limit-Reset: 1486440206.494
Date: Tue, 07 Feb 2017 03:59:37 GMT
Connection: close
Transfer-Encoding: chunked
Set-Cookie: SERVERID=; Expires=Thu, 01-Jan-1970 00:00:01 GMT; path=/
Cache-control: private
a
1 success
0
closing connection
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
No as it fails directly after the first successful GET, I I tried my mobile hotspot instead:
missing...
Connecting to XT1068 5847
WiFi connected
IP address:
192.168.43.11
HTTP/1.1 200 OK
X-Rate-Limit-Remaining: 299
X-Rate-Limit-Reset: 1486437072.963
Date: Tue, 07 Feb 2017 02:56:13 GMT
Connection: close
a
1 success
0
closing connection
Requesting URL: /input/MGXg6JxO47cj1OKAJoZr?private_key=xxx&rh=2&apssid=IOT123+tu-gro+133&temp=85.4&z1lighton=true&z2lighton=false&z1soilmoisture=50&z2soilmoisture=50&z1waterdoses=1&z2waterdoses=1
HTTP/1.1 200 OK
X-Rate-Limit-Remaining: 298
Date: Tue, 07 Feb 2017 02:57:17 GMT
Connection: close
a
1 success
0
closing connection
Requesting URL: /input/MGXg6JxO47cj1OKAJoZr?private_key=xxx&rh=3&apssid=IOT123+tu-gro+133&temp=85.4&z1lighton=true&z2lighton=false&z1soilmoisture=50&z2soilmoisture=50&z1waterdoses=1&z2waterdoses=1
>>> Client Timeout !
Requesting URL: /input/MGXg6JxO47cj1OKAJoZr?private_key=xxx&rh=4&apssid=IOT123+tu-gro+133&temp=85.4&z1lighton=true&z2lighton=false&z1soilmoisture=50&z2soilmoisture=50&z1waterdoses=1&z2waterdoses=1
HTTP/1.1 200 OK
X-Rate-Limit-Remaining: 297
Date: Tue, 07 Feb 2017 02:58:29 GMT
Connection: close
a
1 success
0
closing connection
Requesting URL: /input/MGXg6JxO47cj1OKAJoZr?private_key=xxx&rh=5&apssid=IOT123+tu-gro+133&temp=85.4&z1lighton=true&z2lighton=false&z1soilmoisture=50&z2soilmoisture=50&z1waterdoses=1&z2waterdoses=1
HTTP/1.1 200 OK
X-Rate-Limit-Remaining: 296
Date: Tue, 07 Feb 2017 02:59:33 GMT
Connection: close
a
1 success
0
closing connection
Requesting URL: /input/MGXg6JxO47cj1OKAJoZr?private_key=xxx&rh=6&apssid=IOT123+tu-gro+133&temp=85.4&z1lighton=true&z2lighton=false&z1soilmoisture=50&z2soilmoisture=50&z1waterdoses=1&z2waterdoses=1
HTTP/1.1 200 OK
X-Rate-Limit-Remaining: 295
Date: Tue, 07 Feb 2017 03:00:36 GMT
Connection: close
a
1 success
0
closing connection
Requesting URL: /input/MGXg6JxO47cj1OKAJoZr?private_key=xxx&rh=7&apssid=IOT123+tu-gro+133&temp=85.4&z1lighton=true&z2lighton=false&z1soilmoisture=50&z2soilmoisture=50&z1waterdoses=1&z2waterdoses=1
HTTP/1.1 200 OK
X-Rate-Limit-Reset: 1486437203.398
Date: Tue, 07 Feb 2017 03:01:40 GMT
Connection: close
a
1 success
0
closing connection
So it looks like I am being blocked by IP.
I turned my firewall off on the failed connection, to no avail.
Any ideas?
Thanks,
nicu
