- Sat Feb 04, 2017 12:23 pm
#193248
So I've been tearing my hair out trying to get logic level converters to work with my ESP32 thing, I've tried the sparkfun bi-directional and most recently 8-channel bidirectional breakout modules based on the TI TXS0108E.
Being an electronics noob, I've made a few pratfalls along the way - like not realising that the sparkfun converter has pin levels default to high - anyway - after a whole week of banging my head bloody, it looks like my issue is Pin 12 on the sparkfun board.
If I connect pin 12 to a logic level converter channel - the ESP32 goes haywire and wont boot, it's only just now that I thought to check using different pins on the sparkfun ESP32 board - and apart from pin 12, all the other pins seem to work ok - at a very basic level at least; the board boots and I can check the logic level conversion with a multimeter and a simple loop that swaps low and high every ten seconds.
Looking at the beautiful pinout diagram Sparkfun provides, I obviously avoided pins 39,38,37,36,35, and 34 - but I just assumed I could use Pin 12 as an output. Is that wrong? is there something special about "HSPI_Q" that disqualifies it from being used as output?
thanks,
Kevin.
thanks,
Kevin.
