- Wed Jan 25, 2017 9:12 am
#193087
I have two Sparkfun wireless joystick kits. One is soldered together with XBee and 400mAh Lipo with resistor and the R_PROG jumped with solder. I do see three pads between the R_PROG and 500mA that is printed on the board, are all supposed to be soldered together?
I have Arduino IDE 1.6.11, with Arduino board definitions (ARM cortex-M0+) version 1.6.9 and Sparkfun SAMD boards (dependency: Arduino SAMD Boards 1.6.9) version 1.3.2 installed.
I have downloaded and extracted the windows device drivers to my desktop per the SAMD21 Mini/Dev Breakout HookUp guide.
I plugged in the soldered board first and found "Other Devices". This is where all goes down hill. I just can't get the device manager to install the drivers no matter what I do. I see it on the Ports and in "Other Devices" the Ports drivers do install the drivers but not the "Other Devices".
I went ahead and tried the unsoldered Wireless joystick kit without anything done to board and I get the same errors. No change.
I also tried to open the Arduino IDE and upload the code. It compiles, I can select the COM port but there is no name next to the Port: COM12 like I seen in the guide. I have the board selected so I am missing something?
with Verbose on, the code compiles and tries to force reset using 1200bps open/close on port COM12. Following that I see several attempts and a statement "Uploading using selected port: COM12 then a very long file path name:
C:Users\Bill\AppData\Local\Arduino15\packages\arduino\tools\bossac.exe -I -d --port=com12 -U true -I -e -w -v C:\Users\Bill~1\AppData\Local\Temp\builda48f29dc.(a bunch more numbers here) .tmp/Spardkfun_Joystick.ino.bin -R.
Then in red text I see
Set binary mode
Send auto-baud
Set binary mode
No device found on COM12
Any help is good help.
First, you’ll need to install a variety of tools, including low-level ARM Cortex libraries full of generic code, arm-gcc to compile your code, and bossa to upload over the bootloader. These tools come packaged along with Arduino’s SAMD board definitions for the Arduino Zero.I don't need to go to the other sites for anything right? its all in the Arduino's SAMD definitions.
Set binary mode
Send auto-baud
Set binary mode
