- Mon Jan 16, 2017 2:12 pm
#192934
I'm controlling a WAV trigger serially using an Arduino UNO and the wavTrigger Lib.
In addition to Play & Stop commands I'm using the Pause & Resume serial calls.
When you Pause & Resume a track in the middle of a sound wave you get an audible 'pop' or 'click'
I would like to be able to combine the Fade function with Pause & Resume to get rid of the click.
To have a quick volume Fade before the Pause is called. And a quick Fade up just before the Resume is called.
Is this possible? What would the syntax for this be??
Thank you.
Thank you.
