- Mon Jan 09, 2017 1:13 pm
#192837
I have built a circuit that takes the reflection of a red dot laser and outputs 5vdc when the beam is broken. The problem I am running into is when more than one sensor is linked together. I start getting voltage to build up on the sensor output. The link below will show how the circuit is designed. I am not sure where the problems are but the circuit will work individually.
