- Sat Nov 12, 2016 4:59 pm
#192315
I want to use 9DOF stick with ADXLthis sensor to get angle on one axis. So, I am taking arcsin of the values to get the angle but then i realize that it is not touching the maximum value 1.00. So, sometimes i can't get 90 degree and it would be 7 degree difference.
I will use gyro too. So, it will give accurate angle in motion.
The output values are from 0.00 to 1.00, I want to convert into 0.000 to 1.000 or may be 1.0000 So, i can also get the degree and minutes accurately.
My configuration is :
952 Hz samplerate ( bandwidth is -1)
high resolution is enabled with ODR/400.
Thank you folks in advance !
