By Kamool
#191238
I'm building sensor that senses whenever weight is removed off it. I wanted to use Force sensitive resistor (https://www.sparkfun.com/products/9375), but it says it can measure force in range of 100g-10kg.
Thrre is a problem for me, because sometimes force will reach 20kg. Reaching 20kg means damage of sensor or it just wont sense that?
By lyndon
#191244
If all you want is to detect it and not actually measure it, you could do the same thing essentially for free with two pieces of metal/wire and something springy to separate them. It will work for any load you want, from grams to tonnes.
By Kamool
#191247
Yeah, i know, but that wont work for me. The thing is i need to measure up to 10kg, but there will be more for sure.
By lyndon
#191249
Those things aren't really meant to measure weight, so don't count on accuracy. They are exactly what their name says: resistance changes with force, no guarantees on the same force always giving the same resistance. They are typically only repeatable to within 25% or so.
