- Wed Jul 20, 2016 12:32 pm
#190747
Hello, I am doing a project where I am connecting a photto-interrupter signal to a debounce circuit, and tying the debounce circuit output to the tiny RST on the ESP8266 Thing (not the DTR pin and not the RST pin on the ESP8266 Developer board). I am using this pin because I want to bypass the 0.1 micro-farade capacitor on purpose, I don't know what purpose does it serve (please explain if you're aware). There are no information about the RST pin in the ESP8266 hookup guide, however, ESP8266 Developer board hookup guide states that there is a 10K ohm pull up resistor, so I am assuming something similar with the regular ESP8266.
My questions are:
How does that pull up resistor work with the processor's RST? Does the processor reboot on the low edge? or low itself? and if so for how many milli-seconds does it need to be low for? I also noticed the phant posting or the rest of the script itself doesn't execute if the RST stays at low, is this true for others (it would make sense becuase of the pull up resistor)? or is it the positive edge itself that is suppose to get the rest of the code working?
Thanks for any help that you guys can provide me with!
Please let me know if I need to clarify any of my question/project setup,
MO
My questions are:
MO
