- Tue Jul 12, 2016 7:46 am
#190618
I've just put my hands on the mighty Sunny Buddy V13 and I'm making some tests with a small 6V solar panel. This panel has got the following specifications:
Voc: 7,50V
Vmp: 6,00V
Isc: 1,07A
I'm experiencing this problem: when the panel is under good sun conditions, (e.g. 7,08 Voc) the charger doesn't start. (no current)
If, instead, I put temporary the solar panel in shadow (e.g. 6,33-6,50 Voc) and I disconnect-connect the input, the charger starts and has a small current running through it (and it's correct, it's in shadow). If then I move it to the sun, it gains the full amperage. But again, under the sun if I disconnect the input for a while and I reconnect it suddenly, the IC doesn't start anymore.
I have seen in LT3652 datasheet that:
if Vbat(flt) <= 4.2V
Operating Voltage is Vbat(flt) + 0,75V = 4.95V (and that's ok)
Start Voltage is Vbat(flt) + 3,3V = 7,5V (and that's might be a problem, here)
I have the sensation that there's something wrong in the startup voltage but I can't understand yet what's going on here. Do you kindly have any suggestion? This problem has put down all my enthusiasm because this chip is really really interesting and I would like to make it work.
Thank you in advance.
Best,
Nicola
Voc: 7,50V
Vmp: 6,00V
Isc: 1,07A
Best,
Nicola
