- Tue Mar 15, 2016 8:22 am
#188712
I have the Lilypad Simblee board (Lilypad with Simblee bluetooth chip included on the board). I am attempting to connect an IMU sensor to the board, which uses I2C communication. For this, I need to connect the SCL and SDA ports on the sensosr to pins on the board. I know on a normal lilypad, pins A5 and A4 handle this, not sure which pins I can use for I2C on this board
Any help would be awesome!
**SOLVED**
I contacted Simblee, they told me that the default I2C pins were 5(SCL) and 6(SDA). Also that the default pins could be changed be by replacing the Wire.begin() line with:
Wire.beginOnPins(pin, pin)
**SOLVED**
