Open source ARM Debugger
By reddish
#188579
Hello all,
I recently bought an ATSAM4E-XPRO development board. I want to use OpenOCD to interface with this board. The most important functionality at this point would be uploading / starting executable images; later on it will be useful to use GDB for remote debugging.
I am using Debian that includes OpenOCD v0.9.0. If I list supported atmel boards (/usr/share/openocd/scripts/board/atmel_*) I see a bunch of boards that appear close, but the atmel_sam4e_xplained_pro.cfg is not among them:
atmel_at91sam7s-ek.cfg
atmel_at91sam9260-ek.cfg
atmel_at91sam9rl-ek.cfg
atmel_sam3n_ek.cfg
atmel_sam3s_ek.cfg
atmel_sam3u_ek.cfg
atmel_sam3x_ek.cfg
atmel_sam4e_ek.cfg
atmel_sam4l8_xplained_pro.cfg
atmel_sam4s_ek.cfg
atmel_sam4s_xplained_pro.cfg
atmel_samd20_xplained_pro.cfg
atmel_samd21_xplained_pro.cfg
atmel_samg53_xplained_pro.cfg
atmel_saml21_xplained_pro.cfg
atmel_samr21_xplained_pro.cfg
I have two questions:
(1) I presume writing a config file for the board I have can be as simple as taking one of the existing configs and changing one or two things. What would be the best starting point, and what would I need to change?
(2) Once I can contact the board, what is a sequence of commands or script to transfer an executable image compiled on my host machine and start it?
I checked the manual but it is still a bit daunting (given that this is my first encounter with OpenOCD). So any help will be greatly appreciated!
Kind regards,
Sidney
By reddish
#190234
Hi Kev,
It turns out that the SAM4E EK board configuration works on my XPlained Pro board as well. After compilation, to upload an image, I simply do this from the Linux command line:
sudo openocd -f interface/cmsis-dap.cfg -f board/atmel_sam4e_ek.cfg -c "program image.elf verify reset exit"
So you may get lucky just trying a config file that is close to your board, as long as it lists the correct Atmel microcontroller model there's a decent chance it will work.
Regards Sidney
