- Sat Nov 28, 2015 9:06 am
#186219
I recently purchased Edison with mini breakout board and it work OK. I then bought few Sparkfun blocks, battery block among them. But I have trouble with booting up Edison. USB cable is attached, blue power led is on, red charging led is on (battery is not attached), but edison is probably not booting. It does not connect to my wifi. when moved back to original mini breakout, it boots up and connects to Wifi. It does nothing with Battery block. I also added GPIO block. It says that it is possible to power the stack through GPIO pins. So I attached 3.3V to VSYS, blue led on battery block is on, red is not, but nothing happens. Edison is still not booting up. Do I need another block to make it start? If so, how am I supposed to use is with just battery block and for example 9-axis?
