- Mon Nov 23, 2015 6:22 pm
#186125
I am using the sparkfun VL6180 Rangefinder Sensor, I am unable to find how to get an output of the distance to target that gives accuracy less than the nearest mm (if it is possible). I think this data must exist from the sensor but the coding is clipping it somewhere in the processing, I would like to be able to see if the distance is 12.6mm instead of 13mm for example.
I have looked around in the functions of the demo library (https://github.com/sparkfun/ToF_Range_F ... sor-VL6180) and read through the datasheet (https://cdn.sparkfun.com/datasheets/Sen ... 112632.pdf) for a long while and have tried to find a way through various functions mainly focusing on 'RESULT__RANGE_RAW' but unfortunately with no luck.
Any help on this that anyone could offer, even just to point me towards the right methodology would be amazing.
Thankyou, Sam
Thankyou, Sam
