- Wed Apr 30, 2014 7:23 pm
#170687
Hey all,
I'm looking to design a small (semi)hobbyist board. Part of my design calls for a series of indicator LEDs. I plan on using a TI TLC5925 constant-current LED driver. It calls for a current set resistor, and I'd like to put a resistor and trim-pot in series to set a minimum R, but allow for user adjustment to set LED brightness as desired.
My question is, what can you expect in terms of the "default" value for a trim-pot to come from the factory as? If I ordered a bunch of 5K linear taper trimmer, should I expect them to all come set at 5K, all set to 2.5K, all set to 0, or some random distribution of values?
Thanks!
Thanks!
