- Thu Feb 13, 2014 7:34 am
#168411
Issue :
The error that I'm getting is when everything is connected with the below workflow, I only get the msg "$GPTXT,01,01,02,u-blox ag - www.u-blox.com*50".
Workflow:
GP-635T GPS TX -> RX Xbee Pro S3B -> Xbee Pro S3B TX -> Explorer USB (with RSSI cut mod) -> Serial Console Putty
Xbee Pro S3B Set to 19200, port is 9600
GP-635T output is 9600
Troubleshooting:
I have verified that the GPS module is working fine by sending the GP-635T TX output to a standard FTDI cable and output is seen in the correct GPS format.
I have swapped the Xbee Pro S3B (900) with Xbee Pro S2B (2.4) and the GPS sentences are correct.
I have attached the Xbee Pro S3B output directly to another serial port and Tx/Rx transmission is correct.
The issue only occurs when I connect the GPS output to the Xbee Pro S3B input, is where I see the issue.
It does appear someone on the Xbee Pro S3B is loading down the GPS module?
Thanks,
Curtis
Workflow:
Troubleshooting:
Thanks,
Curtis
