- Fri Nov 08, 2013 8:32 am
#165365
I'm working on a board that will take readings from 8 thermocouples using AD595. I haven't done much work (any) with PCB designs before so if someone could take a quick look and see if there is anything obvious I should be changing on the board, especially the routing, that would be great. This is coming out of the eagle autorouter which I have read is not very good but I need help on figuring out what it might be doing wrong. I will fill in a ground plane on the top and an analog ground plane on the bottom after I get all the routing figured out.
I tried to post this a few days ago but it never showed up. I hope it doesn't double post.
Thanks.
Thanks.
