- Mon Oct 28, 2013 5:27 pm
#164966
Hello, noob here.
I am creating my own PCI-type connector (exposed metal tabs) but with fewer pins. The connector is double sided, but the top and bottom are redundant (they are connected to each other off the board). How do I tell Eagle that? I currently have an output pin in the schematic connected to the top and bottom tabs, but Eagle adds a via to make that happen (undesired).
The desired result is that pin leading to the simplest circuit is used.
Istvan.
Edited to add desired result
Istvan.
