- Sun Oct 13, 2013 3:18 am
#164383
Hi!
I have been using OpenOCD previously to connect and debug my STM32F4Discovery but after a reinstall of the computer I cannot get it to work and I have no idea what is wrong.
Usually I just install the driver via the ST-LINK Utility and OpenOCD works, but not this time.
I am using Windows 7 x64 and OpenOCD 0.7.0.
When I run the command openocd-0.7.0.exe -f ..\scripts\board\stm32f4discovery.cfg I get the cryptic error:
Does anyone know how to fix this?
Best Regards
Emil, Sweden
And if I use the debug command:
Open On-Chip Debugger 0.7.0 (2013-05-05-10:41)
Licensed under GNU GPL v2
For bug reports, read
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : This adapter doesn't support configurable speed
Error: open failed
in procedure 'transport'
in procedure 'init'
which says that it fail at:
User : 13 8 command.c:549 command_print(): debug_level: 3
Debug: 14 18 configuration.c:45 add_script_search_dir(): adding C:/Users/Korken/Desktop/openocd-0.7.0/bin/..
Debug: 15 29 configuration.c:45 add_script_search_dir(): adding C:/Users/Korken/Desktop/openocd-0.7.0/bin/../share/openocd/scripts
Debug: 16 42 configuration.c:45 add_script_search_dir(): adding C:/Users/Korken/Desktop/openocd-0.7.0/bin/../scripts
Debug: 17 53 configuration.c:86 find_file(): found ..\scripts\board\stm32f4discovery.cfg
Debug: 18 61 configuration.c:86 find_file(): found C:/Users/Korken/Desktop/openocd-0.7.0/bin/../scripts/interface/stlink-v2.cfg
Debug: 19 72 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_interface hla
Debug: 20 79 command.c:145 script_debug(): command - interface ocd_interface hla
Debug: 22 86 command.c:369 register_command_handler(): registering 'ocd_hla_device_desc'...
Debug: 23 94 command.c:369 register_command_handler(): registering 'ocd_hla_serial'...
Debug: 24 101 command.c:369 register_command_handler(): registering 'ocd_hla_layout'...
Debug: 25 108 command.c:369 register_command_handler(): registering 'ocd_hla_vid_pid'...
Debug: 26 114 command.c:369 register_command_handler(): registering 'ocd_stlink_api'...
Debug: 27 121 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla_layout stlink
Debug: 28 129 command.c:145 script_debug(): command - hla_layout ocd_hla_layout stlink
Debug: 30 136 hla_interface.c:167 hl_interface_handle_layout_command(): hl_interface_handle_layout_command
Debug: 31 145 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla_device_desc ST-LINK/V2
Debug: 32 156 command.c:145 script_debug(): command - hla_device_desc ocd_hla_device_desc ST-LINK/V2
Debug: 34 164 hla_interface.c:141 hl_interface_handle_device_desc_command(): hl_interface_handle_device_desc_command
Debug: 35 174 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla_vid_pid 0x0483 0x3748
Debug: 36 183 command.c:145 script_debug(): command - hla_vid_pid ocd_hla_vid_pid 0x0483 0x3748
Debug: 38 191 hla_interface.c:195 hl_interface_handle_vid_pid_command(): hl_interface_handle_vid_pid_command
Debug: 39 200 configuration.c:86 find_file(): found C:/Users/Korken/Desktop/openocd-0.7.0/bin/../scripts/target/stm32f4x_stlink.cfg
Debug: 40 210 configuration.c:86 find_file(): found C:/Users/Korken/Desktop/openocd-0.7.0/bin/../scripts/target/stm32_stlink.cfg
Debug: 41 221 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_transport select hla_swd
Debug: 42 229 command.c:145 script_debug(): command - ocd_transport ocd_transport select hla_swd
Debug: 43 237 hla_transport.c:187 hl_transport_select(): hl_transport_select
Debug: 44 243 command.c:369 register_command_handler(): registering 'ocd_hla'...
Debug: 45 249 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 46 256 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 47 261 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 48 268 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 49 274 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 50 280 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 51 287 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 52 293 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 53 299 command.c:369 register_command_handler(): registering 'ocd_jtag'...
Debug: 54 306 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla newtap stm32f4x cpu -expected-id 0x2ba01477
Debug: 55 316 command.c:145 script_debug(): command - ocd_hla ocd_hla newtap stm32f4x cpu -expected-id 0x2ba01477
Debug: 56 325 hla_tcl.c:104 jim_hl_newtap_cmd(): Creating New Tap, Chip: stm32f4x, Tap: cpu, Dotted: stm32f4x.cpu, 2 params
Debug: 57 334 hla_tcl.c:114 jim_hl_newtap_cmd(): Processing option: -expected-id
Debug: 58 341 core.c:1323 jtag_tap_init(): Created Tap: stm32f4x.cpu @ abs position 0, irlen 0, capture: 0x0 mask: 0x0
Debug: 59 350 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target create stm32f4x.cpu hla_target -chain-position stm32f4x.cpu
Debug: 60 362 command.c:145 script_debug(): command - ocd_target ocd_target create stm32f4x.cpu hla_target -chain-position stm32f4x.cpu
Debug: 61 374 target.c:1615 target_free_all_working_areas_restore(): freeing all working areas
Debug: 62 381 command.c:369 register_command_handler(): registering 'ocd_arm'...
Debug: 63 388 command.c:369 register_command_handler(): registering 'ocd_arm'...
Debug: 64 394 command.c:369 register_command_handler(): registering 'ocd_arm'...
Debug: 65 400 command.c:369 register_command_handler(): registering 'ocd_arm'...
Debug: 66 406 command.c:369 register_command_handler(): registering 'ocd_arm'...
Debug: 67 412 command.c:369 register_command_handler(): registering 'ocd_arm'...
Debug: 68 419 hla_target.c:299 adapter_target_create(): adapter_target_create
Debug: 69 425 hla_target.c:272 adapter_init_arch_info(): adapter_init_arch_info
Debug: 70 430 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 71 438 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 72 445 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 73 452 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 74 459 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 75 466 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 76 473 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 77 480 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 78 487 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 79 494 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 80 501 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 81 508 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 82 515 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 83 522 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 84 529 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 85 536 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 86 543 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 87 550 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 88 557 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 89 564 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 90 572 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 91 578 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 92 585 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 93 592 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 94 599 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 95 607 command.c:369 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 96 613 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu configure -work-area-phys 0x20000000 -work-area-size 0x1
Debug: 97 628 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu configure -work-area-phys 0x20000000 -work-area-size 0x10000 -work-a
Debug: 98 642 target.c:1615 target_free_all_working_areas_restore(): freeing all working areas
Debug: 99 650 target.c:1615 target_free_all_working_areas_restore(): freeing all working areas
Debug: 100 657 target.c:1615 target_free_all_working_areas_restore(): freeing all working areas
Debug: 101 664 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_flash bank stm32f4x.flash stm32f2x 0 0 0 0 stm32f4x.cpu
Debug: 102 676 command.c:145 script_debug(): command - ocd_flash ocd_flash bank stm32f4x.flash stm32f2x 0 0 0 0 stm32f4x.cpu
Debug: 105 686 command.c:369 register_command_handler(): registering 'ocd_stm32f2x'...
Debug: 106 693 command.c:369 register_command_handler(): registering 'ocd_stm32f2x'...
Debug: 107 700 command.c:369 register_command_handler(): registering 'ocd_stm32f2x'...
Debug: 108 707 tcl.c:781 handle_flash_bank_command(): 'stm32f2x' driver usage field missing
Debug: 109 713 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_reset_config srst_only srst_nogate
Debug: 110 723 command.c:145 script_debug(): command - reset_config ocd_reset_config srst_only srst_nogate
User : 112 731 command.c:549 command_print(): srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Debug: 113 742 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 114 748 command.c:145 script_debug(): command - init ocd_init
Debug: 116 754 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target init
Debug: 117 763 command.c:145 script_debug(): command - ocd_target ocd_target init
Debug: 119 769 target.c:1178 handle_target_init_command(): Initializing targets...
Debug: 120 775 hla_target.c:289 adapter_init_target(): adapter_init_target
Debug: 121 781 command.c:369 register_command_handler(): registering 'ocd_target_request'...
Debug: 122 789 command.c:369 register_command_handler(): registering 'ocd_trace'...
Debug: 123 795 command.c:369 register_command_handler(): registering 'ocd_trace'...
Debug: 124 802 command.c:369 register_command_handler(): registering 'ocd_fast_load_image'...
Debug: 125 809 command.c:369 register_command_handler(): registering 'ocd_fast_load'...
Debug: 126 815 command.c:369 register_command_handler(): registering 'ocd_profile'...
Debug: 127 822 command.c:369 register_command_handler(): registering 'ocd_virt2phys'...
Debug: 128 828 command.c:369 register_command_handler(): registering 'ocd_reg'...
Debug: 129 835 command.c:369 register_command_handler(): registering 'ocd_poll'...
Debug: 130 842 command.c:369 register_command_handler(): registering 'ocd_wait_halt'...
Debug: 131 848 command.c:369 register_command_handler(): registering 'ocd_halt'...
Debug: 132 855 command.c:369 register_command_handler(): registering 'ocd_resume'...
Debug: 133 861 command.c:369 register_command_handler(): registering 'ocd_reset'...
Debug: 134 868 command.c:369 register_command_handler(): registering 'ocd_soft_reset_halt'...
Debug: 135 875 command.c:369 register_command_handler(): registering 'ocd_step'...
Debug: 136 881 command.c:369 register_command_handler(): registering 'ocd_mdw'...
Debug: 137 888 command.c:369 register_command_handler(): registering 'ocd_mdh'...
Debug: 138 894 command.c:369 register_command_handler(): registering 'ocd_mdb'...
Debug: 139 900 command.c:369 register_command_handler(): registering 'ocd_mww'...
Debug: 140 907 command.c:369 register_command_handler(): registering 'ocd_mwh'...
Debug: 141 913 command.c:369 register_command_handler(): registering 'ocd_mwb'...
Debug: 142 919 command.c:369 register_command_handler(): registering 'ocd_bp'...
Debug: 143 925 command.c:369 register_command_handler(): registering 'ocd_rbp'...
Debug: 144 931 command.c:369 register_command_handler(): registering 'ocd_wp'...
Debug: 145 938 command.c:369 register_command_handler(): registering 'ocd_rwp'...
Debug: 146 944 command.c:369 register_command_handler(): registering 'ocd_load_image'...
Debug: 147 951 command.c:369 register_command_handler(): registering 'ocd_dump_image'...
Debug: 148 958 command.c:369 register_command_handler(): registering 'ocd_verify_image'...
Debug: 149 965 command.c:369 register_command_handler(): registering 'ocd_test_image'...
Debug: 150 973 command.c:369 register_command_handler(): registering 'ocd_reset_nag'...
Debug: 151 979 command.c:369 register_command_handler(): registering 'ocd_ps'...
Debug: 152 985 hla_interface.c:107 hl_interface_init(): hl_interface_init
Debug: 153 991 hla_layout.c:91 hl_layout_init(): hl_layout_init
Info : 154 995 core.c:1375 adapter_init(): This adapter doesn't support configurable speed
Debug: 155 1003 openocd.c:132 handle_init_command(): Debug Adapter init complete
Debug: 156 1009 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_transport init
Debug: 157 1017 command.c:145 script_debug(): command - ocd_transport ocd_transport init
Debug: 159 1023 transport.c:240 handle_transport_init(): handle_transport_init
Debug: 160 1029 hla_transport.c:148 hl_transport_init(): hl_transport_init
Debug: 161 1035 hla_transport.c:165 hl_transport_init(): current transport hla_swd
Debug: 162 1042 hla_interface.c:44 hl_interface_open(): hl_interface_open
Debug: 163 1047 hla_layout.c:42 hl_layout_open(): hl_layout_open
Debug: 164 1052 stlink_usb.c:1233 stlink_usb_open(): stlink_usb_open
Debug: 165 1056 stlink_usb.c:1251 stlink_usb_open(): transport: 1 vid: 0x0483 pid: 0x3748
Error: 166 1087 stlink_usb.c:1254 stlink_usb_open(): open failed
Debug: 167 1091 hla_layout.c:49 hl_layout_open(): failed
Debug: 168 1095 command.c:631 run_command(): Command failed with error code -4
User : 169 1100 command.c:669 command_run_line(): in procedure 'transport'
Debug: 170 1107 command.c:631 run_command(): Command failed with error code -4
User : 171 1112 command.c:669 command_run_line(): in procedure 'init'
Debug: 172 1118 hla_interface.c:115 hl_interface_quit(): hl_interface_quit
However this is the correct VID and PID. And I have no idea of what goes wrong.Debug: 164 1052 stlink_usb.c:1233 stlink_usb_open(): stlink_usb_open
Best Regards
Emil, Sweden
