- Tue Jun 18, 2013 11:16 am
#160659
I did this layout last night. I used the mosfet amps from radio shack and a regulator I had around.
I have attached the board and an image of what the pins connect to.
The only issue currently is the RGB strip lights up when the motor is running.
I added a diode to keep my self from blowing up stuff when I'm tired and do something stupid and the resistor if for the i/o pin that was never sure if it was high or low.
First problem is the RGB strip light up a little when the motor runs. Other than that everything seems to work great.
